need a favor (rear springs)
Old Dec 28, 2007 | 12:57 PM
blacksheep-1's Avatar
Default need a favor (rear springs)
Could one of you guys give me the inside diameter of a rear spring at both the top and bottom. Inside would be the distance across the spring, where it meets the isolator, but not counting the spring coil itself. This would be on a 99 GT or similar model. Thanks
Old Dec 28, 2007 | 03:09 PM
c'mon guys, someone out there has to have a rear diff sitting around that they can measure the spring perch on...........
Old Dec 28, 2007 | 05:35 PM
Adrenalin's Avatar
Project Fobra
The top inside diameter on my stock '95 springs is 4" inside diameter
The bottom inside diameter is a little tricky. It isn't a perfect circle so the most narrow inside diameter that I got was 2.25" inside diameter.
I would think the springs would be the same on my car as yours but not 100% certain.
Hope this helps
Terry
Click - FQuick
flickr
Old Dec 29, 2007 | 06:05 AM
thanks for the help-Rob
