Prepping block for head gaskets
Old Dec 23, 2007 | 11:04 AM
Alan's Avatar
drives euro trash
Default Prepping block for head gaskets
I'm in the process of prepping my block for new head gaskets. I've scraped off all I could with razor blades. I was advised to find a red scotch brite type attachment for my power drill to knock off the remainder of the gasket material down to the bare metal.
I'm having one hell of a time finding anything to get this done...been to NAPA, Lowes, Home Depot, Pep Boys, Sears, etc. Can't find shit.
So what do you all use get this shit off the block?
Old Dec 23, 2007 | 12:07 PM
topher469's Avatar
BillionClub Member BISHES
I have always got my Roloc's from Napa! Sucks they don't have them.
Originally Posted by DrDirt
You also make a foolhardy leap of faith in assuming that the government can execute a program properly when they can't even execute terrorists properly!!!
Old Dec 23, 2007 | 02:29 PM
Tiffiny's Avatar
I can fix your bullshit
wire wheel 4 a drill works in a pinch
Old Dec 23, 2007 | 02:38 PM
**CHRIS**'s Avatar
Called the amba lamps
Wire wheel will work but you have to be very carefull to only scrape off what you need to...if you get too heavy with the wire wheel your head gaskets won't have a flat surface to mount to.
Old Dec 23, 2007 | 04:02 PM
Steve B's Avatar
brings his heater.
i always just wiped them deck with brake clean sprayed into a rag
Old Dec 23, 2007 | 05:24 PM
GNs-r-slow's Avatar
Bondsman
I use the green scotch-brite cookies from Advanced in body section. With any abrasive you dont want to sand in one spot, only remove gasket
