MSD on a 2.3?
is this possible and if so which modle do i use for a 92 mustang 2.3. it has 2 plugs per cylinder. also if i had put the svo head on it, would it run with no problem? or would i have to get the ecu reprogramed? cuz i know ill be going from 2 coil pack too 1 pack.
its ok, the more parts that fall of the lighter i get.
msd makes a ignition for dis motors
The only reason to go with the iron SVO head is if your going turbo.
The duel plug heads flow better and have a more efficient combustion chamber.
If you try and put the inline intakes on a turbo head the intake paths won't line up.
"They must really feed each other to the lions down there........"
well i want to do turbo but i dont know how much the non turbo 2.3 can handle. and with the intake thing. i would like to get the svo intake. it just seems more efficient. ok also i found my msd coil's," fucking 85 bucks apiece!".
but i figure sence i cant get anything i want out of my vert im just gonna do a home made project with it.
ok well how about this. i found the old svo style upper and lower intakes at the junk yard for like 30 bucks a peice. now if im right, this should bolt right up no problem to my 92 2.3. now im thinking, full MSD ignetion set up, cold/ram air intake (which is supose to be custom made with mas air sensor built into it) if it fits, the 5.0 throttle body.upgraded fuel pump and injectors. and should i do away with the egr? i think this should be a nice little start till i can save up for the turbo, intercooler and custom piping.
