4.6 Tremec install
Anyone out there installed a Tremec in a Cobra or GT? My T-45 is about shot and I was thinking about installing a Tremec. Just trying to get any sticking points out of the way before I tackle that sort of job.
<FONT COLOR=#a8a8a8 SIZE=1 FACE=Verdana Arial>This message has been edited by sigep-svt on 12-14-2000 at 10:17 PM</font>
Craig has a 3550 in his Bullit. He is pretty satisfied with it...as well as hundreds of other Mustang owners. The TKO is a good one too...but it requires a different bellhousing and different drive shaft.
2000 Focus ZX3...stock and hatin it.
I thought that both the TKO and 3550 need the Lakewood bellhousing to bolt up to the 4.6?? Craig_302 has a 5.0. I think the Tremec just bolts up to the 5.0.
<FONT COLOR=#a8a8a8 SIZE=1 FACE=Verdana Arial>This message has been edited by sigep-svt on 12-29-2000 at 10:16 PM</font>
Ill have a complete Tremec TKO with the Lakewood Scattershield and a Steeda Tri-Ax Shifter.
Chris
Chris
<b>Whoever will not receive you or listen to your words--go outside that house or town and shake the dust from your feet. </b> Matthew 10:14
The t-56 is a nice tranny but heavy. If u dont have gobs of hp I would lean toward a tko or a tremec. Personally I like the gear ratios of my stock t-45. The first gear is 3.37 which is higher than the t-53550tko. Yes its weak but cheap to rebuild.
98red cobra www.need-4-speed.com
13.31@106.29 (2.08 60ft)
<FONT COLOR=#a8a8a8 SIZE=1 FACE=Verdana Arial>This message has been edited by bitemark46 on 01-12-2001 at 11:44 PM</font>
98' cobra
98' cobra
The 3550 and TKO require differant bellhousing......You might want to look into a Tremec T-45 out of a 99+ mustang, they seem to be a bit stronger then the old T-45s
Does that look normal to you?
