motor mounts ?
When I was looking at putting a 302 in a Ranger the popular mounts to use seemed to be fox body stang mounts..... If you google V8 Ranger you will find a few sites wite alot of info the V8 swaps and the specifics.....
Ford Ranger V-8 Engine Swap
Direct quote...
"Motor Mounts:
Motor mounts can be obtained thru Advance Adapters, James Duff Enterprises and Jegs. Advance Adapters offers Parts NO.713018 for 4WD and NO.713015 for 2WD. The 2WD mounts work with the factory Ford rubber V8 mounts Part NO. E4TZ-6038G or Advance Adapters Part NO. 713017. James Duff only offers 1 mount Part NO. 3641. Jegs offers part# 969-9716 (mounting brackets) and part # 969-9717 (mounting pads). You will have to drill two new holes in your cross member for the new motor mounts. Motor mounts from a 1985 Mustang GT swapped from side to side are said to be the same mounts offered by James Duff. Summit Racing carries motor mounts for Ranger V8 swaps Part# ADD-713018 for 4wd's and Part# ADD-713015A for 2wd's. Ask if you need the V8 rubber mounts Part# ADD-713017."
Direct quote...
"Motor Mounts:
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
