subframe connectors?
believe it or not i have yet to put some subframes on my coupe. any hands on experience or stories about subs that you have used?
i hear steedas full length subs are the way to go. - Full-Length Subframe Connectors - '79-'04 Ford Mustang
these also dont look bad- eBay Motors: 79-93 Ford Mustang 5.0L Full Length Subframe Connectors (item 130166108671 end time Nov-01-07 07:26:26 PDT)
should i go tubular or boxed? pro's & con's?
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Largo Fl 33773
727-667-9346
Steeda's full length or through floor. Only boxed, since your frame is boxed tubular won't do much good, not enough welding surface to connect the frame. Mine had tubulars on when I bought it, switched to steeda's and it's night and day. Going from none to steedas will really impress you
You also normally get better ground clearance with the boxed.
Maximum Motorsports is what i would use.
313/304 new #'s
Only 8.5:1
Engine built and tuned by Coastal Dyno.
313/304 new #'s
Only 8.5:1Engine built and tuned by Coastal Dyno.
Never knock on Death's door: ring the bell and run away! Death really hates that!
- Matt Frewer
One tequila, two tequila, three tequila, floor.
George Carlin
When you step on the brakes your life is in your foot's hands.
George Carlin
- Matt Frewer
George Carlin
George Carlin
