Nitrous guru's: Let me bounce this idea off ya
I pull motors 4 no reason
on
Running Ford GT40 crate motor w/Holley Systemax kit. 24lb injectors and all the other goodies.
Adding N20 and will probably be going w/150-175 shot. Am also upgrading to a 255lph pump.
Car dyno'd at 300hp/308tq n/a
Since it is a WET kit I will not need bigger injectors correct? Friend of mine wanted me to take a look at fuel calculator tables and advised that the injectors couldn't handle a total of 430-450hp (that's including the shot of N2O.) I thought that since it's a wet kit I am supplying the extra fuel and I should be safe. Correct? Car is only raced 6-10 times a year,,won't be spraying a ton. (that's if I don't get addicted to this stuff )
Correct.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
