detonation?
Old Oct 8, 2007 | 09:06 PM
351coupe's Avatar
refinish artist
Lightnings don't have knock sensors.Who tuned it?
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Oct 9, 2007 | 06:05 AM
Krautburner's Avatar
Scissor me timbers!
In reality a performance shop should be able to see what A/F ratio is at WOT.
Alot of things can be ruled out by that.
Things you can check yourself:
If you have a aftermarket intake,check for oil being drawn in.I clean mine every oil change.
Clean off the maf with a quick evaporating cleaner(adv carb cleaner is more like wd40).
Like smoke show said,change the fuel filter.
Any misfire like a cracked coil would throw a code.But you might aswell check your plugs and coil to rule that out.With up'ed boost I hope you went with a colder plug.
Old Oct 9, 2007 | 07:27 AM
EG2DelSol's Avatar
yep i did the iridium ngk's....changed the fuel filter and had 2 regap the plugs cause it was popping bad, so i gapped them smaller and it stopped....but now it's doing it again, but not nearly as bad
FastAsLightning01
Old Oct 9, 2007 | 12:31 PM
351coupe's Avatar
refinish artist
Are they TR6's?I always gapped mine at .32.I know it sounds stupid,but use some di-electic gease and make sure all the coil's are pushed all the way down on the plugs to help with connection.Another problem to check,if you have high miles and stock boots,mine was popping so I got a new boot and spring kit and it cleared it up.Hope this helps.
Old Oct 9, 2007 | 01:33 PM
Scissor me timbers!
Now when you did your plugs,did you jump in without letting the engine heat all the way up and floor it?Or did you let it heat up to normal temp and hit it.
If not,and it cleared up before after you pulled your plugs,its probably an ignition problem.
Take out all your coils and check for little white lines or specs.Take the boots off too.If it was a failed coil it really would show a code.
