ele water pumps????????
Also, I meant the 300 series are pricey, the 100 series arent bad, but the CSR pumps IMO, look better, only 4 bolts to remove the pump from the backing plate.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Ryan
You will have the same cooling effieciency with an electric as with a belt driven. The biggest advantage and IMO the main reason to get one is the ability to run the pump with the motor off on ACC, otherwise unless you are at the point where you are looking for that last 5hp or so maybe save the money and use it towards something else. You might have to take a look at your electrical system as well to make sure you can support the pump. If your system is weak make sure you get that straight before hand.
I remember there being one in the classifieds about a few weeks back.
Ryan
Ryan
