a/c question?
I have a 1990 Bronco II that I just had the r134A refilled and dye tested for leaks...everything appears ok except the air doesn't seem to blow out of the vents on max as it should...it does cool down inside the truck but it takes about 5-10 minutes....Does anyone think it might be my a/c motor on the firewall or this just usual for this year ford?
If you have time, pull it out and clean the motor and fan thuroughly. It just might be dirty...
I had a similar situation with another vehicle and cleaning it helped a bit. But it is an older car/truck, and the system does deteriorate with age..
GL
GL
jeff - there is a great product you can buy that is sprayed up into the evap case through the drain outlet --- this foams and cleans/disinfects and can improve air flow.
Also you may have one of two other problems...
1. air vent distribution issue from vacuum leak or bad vent actuating diaphram and/or...
2. you may be icing at evap which will also restrict/reduce air flow and cooling effectiveness. (cycle switch issue or improper freon charge #'s}
Did you get all that?
Greg
Greg
The '87 Coupe to be built and raced in our son's memory.
Cameron Lee Koss - 9.1.1991 - 8.05.2011
I can do great things when not experiencing "Man-A-Pause" StangItMan '08
Greg
Greg
Most shops know a BG distibutor and many I know like this product:
BG Frigi-Clean®
Odors, bacteria, mold, spores, fungi, road grime, nicotine oils and debris accumulate in your car’s air conditioning evaporator. BG Frigi-Clean® restores heating/cooling efficiency and freshens interior air. It is a unique cleaning solution designed to quickly and effectively remove foul odors, bacteria, mold, spores, fungi, road grime, nicotine oils and debris that accumulate in your car’s air conditioning evaporator. BG Frigi-Clean® is injected directly into the evaporator case. It foams up to completely fill the evaporator core where it also blasts away bug parts, pet hair, nicotine residue and other garbage. BG Frigi-Clean® is biodegradable, non-toxic, non-corrosive.Part No. 709 Net Wt. 7 oz. (198.4 g)
Volume 6.65 fl. oz. (197 mL)
BG Frigi-Clean®
BG Frigi-Clean®
BG Frigi-Clean®
^ yep, what he said.
Also, "Max" is recirculating air within your vehicle, thus... do confirm your vents are functioning properly to allow for this feature to work.
^+1 betting on a evap fin clogging airflow. I use BG products everyday.. Once you either fix the problem. Avoid running the a/c on fresh air, run it on recirculate. That way your not sucking in that hot humid florida air. Once it starts getting on the evap, heating-cooling-heating-cooling, it creates mold which stinks like shit, and tends to cause the buildup on the evap.
We can always choose to percieve things in life differently. It's important to focus more on what's right in life.. versus what is wrong.
