Dohc 4.6 Swap Into 95 T-bird
Mr. Stealyogirl
on
Ok so me and a friend have been doin a DOHC 4.6 SWAP (Mark in his 95 T-Bird. Well for some reason the car wont start and we found out we arent getting ANY spark. It has coil packs not coil on-plug. We replaced plugs, Cam-Crank sensors, and checked all grounds. Can you guys give us some advice???
We need this beast running!!!!
is it getting an injector pulse as well?
Mr. Stealyogirl
on
i dont know what PATS is but i will call him lol The car is chipped to my knowledge
P.A.T.S = (Passive Anti Theft System) Just having a chip will not shut it off. The chip has to be programmed to shut it off.
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Mr. Stealyogirl
on
It doesnt have a Anti-Theft System. Only thing related to that is it has a keyless entry.....
What wiring are you using? I know, no signal from the crank trigger sensor will kill the spark. IIRC PATS only kills the fuel pump.
313/304 new #'s Only 8.5:1
Engine built and tuned by Coastal Dyno.
Never knock on Death's door: ring the bell and run away! Death really hates that!
- Matt Frewer
One tequila, two tequila, three tequila, floor.
George Carlin
When you step on the brakes your life is in your foot's hands.
George Carlin
- Matt Frewer
George Carlin
George Carlin
Mr. Stealyogirl
on
I guess its the same one, The forum hes on, every1 said he could use his old one.
ok nice. That sounds like the issue right their. Hack jobs with factory harness are such a bad idea and almost never work. Don't 95Tbirds have have a 5.0 motor or a v6?
- Matt Frewer
George Carlin
George Carlin
- Matt Frewer
George Carlin
George Carlin
