90 crown vic losing fire
Old Sep 1, 2007 | 07:57 PM
barry bledsoe's Avatar
The lost pony
Default 90 crown vic losing fire
my buddie has a 90 crown vic 5.0 the car starts as soon as you let off the key it looses fire.like there is a switch in the column that is bad or something. it has good fuel pressure 39 tried new coil has new cap rotor wires and plugs.
Old Sep 2, 2007 | 05:48 AM
StangItMan's Avatar
Check harness and its pins to column mounted switch first --- they loosen and walk out as do mustangs.
Switch is only $20 bucks at Advance ... #S128 probably
Lock cylinder/keys is only $20 also
BTW - Ponies?
The '87 Coupe to be built and raced in our son's memory.
Cameron Lee Koss - 9.1.1991 - 8.05.2011
I can do great things when not experiencing "Man-A-Pause" StangItMan '08
Old Sep 2, 2007 | 06:25 AM
The lost pony
thanks man I still have the ponys they are on e bay now I cleaned them up and took new pics 250 with the tires and 2 extra tires like new. If you want to see the new pics I can e mail them to you. I dont know if i still have your e mail address, I would take 200 without the extra 2 tires.
Old Sep 2, 2007 | 06:30 AM
StangItMan's Avatar
stangitman@verizon.net
call me about the 4cyl. stang... 813.737.6077
Old Sep 2, 2007 | 07:57 PM
The lost pony
ok now I replaced the switch make sure all wires are pushed in to the connecter now it wont start, it has fire it has fuel,put noid light on injecter and the one I checked was firing. I check the compression in 2 cyls 60# so I figure the timing chain jumped pull it down and the marks line up. the chain is super loose. will a motor even run with 60# of compression. was running smooth before no blown head gasket clean oil wtf. car does not smoke, it does have a lot of miles on it. the new plugs were black too much fuel ???
