Roller
Old Aug 26, 2007 | 05:14 PM
Subzero's Avatar
Thread Napper
Default Roller
Is there a difference in the Block betweeen a roller and non roller? if so what is it?
Old Aug 26, 2007 | 05:22 PM
topher469's Avatar
BillionClub Member BISHES
hydraulic roller lifters ride on the "roller" camshaft in a roller motor.
Non roller are flat tappet lifters
Originally Posted by DrDirt
You also make a foolhardy leap of faith in assuming that the government can execute a program properly when they can't even execute terrorists properly!!!
Old Aug 26, 2007 | 05:30 PM
shinysideup's Avatar
TR Balla Donor Supreme
blocks are the same. one has some different parts.
Old Aug 26, 2007 | 06:42 PM
fakesnake's Avatar
the blocks are not the same... one is designed to use flat tappet lifters and a roller block uses hydraulic roller lifters...thats why they call one a roller block and one a flat tappet block...ford started using roller blocks in 1985 thru 1995 in mustangs...i think the explorer went untill 1998 with the 5.0
