4 to 5 lug front?
wow, so much bad info in this thread.
the mk7 linc 86-92 spindels will fit but you have to change the ball joint to the linc piece, it's bigger. if you have a 4 cyl, get 87-93 5.0 mustang or 87-88 tbird turbo coupe spindels to use the mk7 rotors.or use the entire setup off a 94-98 mustang . 94-95 keeps stock track width,96-98 will push you out about 8mm wider. the 89-up tbird stuff will not work, and they have a 5x4 1/4 bolt circle instead of the 5x 4 1/2.
this site sucks balls now. fuck tampa racing, not coming back.
