Quick 302 question (or 2)
anyone know the sizes of the following bolts?
front lowest timing cover bolt on pass side.
Motor mount Nuts (that go into the K-member)
Nuts on the motor mount studs (to the motor)
if its too fast your just scared.
5/16 coarse should be 5/16-18, 7/16 coarse should be 7/16-14
9/16 for the mm's btw
rest were correct thank you rep given to both of you
deuce it wouldnt allow me to give you rep---will get you later
