cam question
ok i want to put a z303 cam in my track project mustang 5.0 ....i have ported stock heads and 1.6 roller rockers will i be able to fit it without clearance problems........its a 552 lift.....does anybody know the lobe seperation on this cam?...thanks derek
the COUPE that COULD
fly cutting pistons is done because there is not enough room to run the lift of the cam u are going to do..so u fly cut them to make room so u dont send a piston into the valve.
there is nothing wrong with doing it as long as your piston is thick enough to do it.
check motorsport catalog for their cam specs....no matter what cam you install always clay the pistons to see what you have for clearance....or use a dial indicator and checking springs to do the same...........
