How to wire 3g alternater
Old May 28, 2007 | 03:02 PM
GNs-r-slow's Avatar
Bondsman
Default How to wire 3g alternater
I have an 86 vert was a V-6 now 302. can anyone tell me how to wire a 3g alt? The car has a external regulater on it now and want to get rid of that rats nest of wires.
Rep for a good explanation or wiring diagram. Thanks
Old May 28, 2007 | 03:12 PM
ODB's Avatar
ODB
S.Y.L.O.
You should have 2 connectors...install the connector that fits the 3G...then you cut the second connector off all together.. believe there is a total of 3 wires you will have after cutting the connector off.. Take the 2 larger wires and twist them together. Crimp on a connector and bolt it to the studed fitting on the 3G(post and nut). Take the small wire and crimp on a small connector for the single post terminal on the alt. Then your done....its that fucking easy!! This is how it is with 87-93........I hope its the same for you.
Old May 28, 2007 | 03:13 PM
ChrisN1313's Avatar
http://i119.photobucket.com/albums/o...-late-alt2.jpg
Converting A Ford 2G to 3G Alternator
Old May 28, 2007 | 03:15 PM
ChrisN1313's Avatar
The 3G Alternator Project
http://www.geocities.com/smithmonte/...or_Upgrade.htm
Old May 28, 2007 | 04:37 PM
Na306StAnG's Avatar
Flowmaster nut swinger
OK I have a question. Is there any way to make a 3G a one wire?
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old May 28, 2007 | 07:17 PM
GNs-r-slow's Avatar
Bondsman
Thanks for replies!! One article says buy custom harness, the other says this version coming soon. Has to be easy
Old May 28, 2007 | 07:19 PM
GNs-r-slow's Avatar
Bondsman
NA- I have the old school shit that only has posts on the back of ALT, no plugs at all
