couple of quick q's.
just installed a qa1 k frame in the project, and it seems to sit about 1" lower now. kept the stock a arms, springs (whatta bitch gettin em back in
) and 90/10's. just wondering if its normal to sit a little lower with this k-frame and set up ?
also need a good alignment shop in pinellas.
) and 90/10's. just wondering if its normal to sit a little lower with this k-frame and set up ?also need a good alignment shop in pinellas.
My buddy ran that setup with the stock arms and springs for some reason when you do that it lowers it a little. But when and if u upgrade to tubular a-arms and coil overs it should go back to normal ride height.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
thanks for the info Na..... any leads on a alignment shop ???? don't want to do the typicall tire store, unless i have a contact. ??????
The best place that i know of around is Thompson over in clearwater near gulf to bay and Missouri. I wish i knew of someone closer if you find someone let me know.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
Beleive it or not but if you used Lakewood 90/10's thats probably where that extra 1 in of drop came from. They tend to sit lower for some reason. I installed them on my 97 cobra and thats all I did I didn't change the spring and I was almost an inch lower than what I was. Now to use Lakewood 90/10's in an SN95 you have to use the Fox body part number. Thats where I thought I got the drop from I was told they are an inch shorter than SN95 struts. Maybe they are just and inch short no matter what year they are.
Did the same set-up here too and it was lower, 60ft's great so I am not fugging with it.
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
My cars 60ft was better with that setup then the one I have now. So yea it works.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
thanks for the info guys !!!
