Why 8.8 Explorer rear Offset?
Old May 12, 2007 | 07:18 AM
onebadmaverick's Avatar
Default Why 8.8 Explorer rear Offset?
Can anyone tell me whats the reason for a pinion offset to the pass. side on the 8.8 rears of the explorers?
Old May 12, 2007 | 07:32 AM
Duceanahalf's Avatar
is doing your girlfriend
because the motor is off center, plus to clear the fuel tank with the driveshaft, but probably mostly due to the need for clearance for the 4WD system
Old May 12, 2007 | 07:59 AM
Whenever I looked at the engine it never really looked like it was offset, but it did cross my mind.
Old May 13, 2007 | 05:21 AM
DrDirt's Avatar
Team Geritol Racing
They do that so you can't use them on a Mustang.
YO! Barry! You LOST!
Old May 13, 2007 | 06:12 AM
even a mustangs motor is off set, if your axels are the same width, that means the pinion is not in the centerline of the car, so the motor has to be offset. In my car the motor is about 1" to the passenger side.
Old May 14, 2007 | 03:38 PM
Just Dave's Avatar
Do It In The Dirt
Offset mainly for gas tank clearance. Its a byproduct of the old rangers that started the trend.
29 Hard and Single
My Rail Buggy
