help
car breaks up from idle to 2900 rpms 3000 up revs awsome i cant even burn out went to track last week and car broke up all the way down the track again no power at launch i have one leg and no line lock yet so im launching at idle ,in 1/8 mile 1st run it ran 9.47 dogging 2nd run with nitrous shot rt 5.38 60ft 1.8 then i had to cut it off and hit the brakes popped fire thru the k&n so that was 10.4 at 40 mph i put it on the tralier after that. so i at my wits end with this car!1
can someone tell me what is going on or any info to help me figure this out and what time would i had ran if it wouldnt caught fire i cut it off at about the 100 ft mark thanks in advance gator
Pony Express Racing
Team Lopez motorsports
Tampa horsemen motorsports
Pony Express Racing
Sounds like the power valve is roasted, have you ever sneezed the squeeze back through the carb ?
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
Something else most likely caused your backfire (to much timing ? ) but when it did this it most likely took out your power valve. Make sure when you get a new one you get the sane size, it's stamped on it.
Not sure what you are asking about the et ?
this is my et question
2nd run with nitrous shot rt 5.38 60ft 1.8 then i had to cut it off and hit the brakes popped fire thru the k&n so that run was 10.4 at 40 mph what time would i had ran if it wouldnt caught fire i cut it off at about the 100 ft mark thanks in advance gator
Pony Express Racing
Pony Express Racing
There is really no way to tell what the ET would have been. I did not see you out there wednesday night did you make it out???. Be carefull in here bother there are alot of Carb Nazi's around these parts.....
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
Pony Express Racing
Pony Express Racing
what's that? sounds complicated, don't think I have/need one...
