valve lash setup
guys ,
im trying to help a friend with install of his 303 cam in an older 302 he is using the retrofit roller lifters (comp cams i think) in setting the valve lash id doesn't seam right now i dont know fords well so any info would be a great help .
just to be sure is he using bolt down style rockers or stud mount?
lash is on a solid lifter cam. Most people set the lifter pre-load at between 1/2 and 1 full turn on the nut OR set up enough shims under the pedestal to achieve the same with the bolt.
I do 3/4 turn.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
