Video of my car tonight. And a tech question
No cage!
Well the asshole in the dodge didn't know how to stage so i sat there on the tranny brake for longer then i wanted. No gauge I need one!!!!
I don't think so i'm content with the et but not the 60 if i could get my 60 done to 1.5's or better i'd be very happy. I was told its spinning hard out of the hole but dunno.
Originally Posted by Krautburner
Whats the trans temp when you line up and rev it
Originally Posted by 99cobra281
looks good but yea1.6s is that good for all that and that car
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
you wanna try my 27x10.5 Micky ET street bias plys? throw about 8 lbs of air in them. if that bitch dont hook with em then you go some suspension tuning to do brotha.
she looked real flat leaving from the video .. hook and haul hard as she used to. what did you change and why!?!?!?
yo my freind busted down a 1.7 60 with stock susp and a set of mt ET's full susp should be like 1.5 or better im guessing but still none the less it was a good run ,, looked to be spinning a bit from out the hole what pressure u runnin in the tires we had about 8.5 in ours "COLD" hooked like hell
best of luck to ya
_Eric
best of luck to ya
_Eric
best of luck to ya
_Eric
best of luck to ya
_Eric
Originally Posted by 98svtcobra
whats your pinion angle set at. Ive heard -4 degrees as a good setting. but that setting was on my sn95 cobra, idk about the fox bodies.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
better video's are up.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
Dunno It goes 3800 on the tranny brake.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
no sheet....... Well then i'll look in to that.
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
