Need Help!!
WOULD THIS WORK????
SIZE AND SPECIFICATIONS: We have combined two different size wheels on this auction. There are two 17" x 9" (+24mm with 5.95" backspacing) for the front and two 17"x10.5" (+27mm with 6.9" backspacing) for the rear. They are 5-lug (5 on 4 ½).
Mickey Thompson ET Street Drag Tire
27'' x 10.5'' - 15''LT Which is a 9 inch tire like $hawn already said.
this is how they look and fit
many people have used to 10.5"/315 combo on foxes with success, you just have to remove the quad shocks and beat the living hell out of the inner fenders and roll the lip of the outer fenders. If you wanna go through the trouble it will work, but as $hawn stated, go with the 9" wheel on the rear with some 275s.
mine stuck out about 2" on both sides.... there is no fender rolling to help that. BTW, my fenders are already rolled. It might be because I was using a 97 cobra axle back there, but that is only about 3/4" wider per side..... no quads either....
