Any Help weird issue
Old Apr 3, 2007 | 08:26 AM
ChrisN1313's Avatar
Default Any Help weird issue
4.6 pi 2 valve motor
Car is not firing on the right side at all
We had the car running and it was running very rough. Unplugged all 4 coils no change.. Unplugged all 4 injectors no change
Unplugged 1 injector or coil on the drivers side and it gets worse
Checked the plugs on the right side and they were wet
Checked the spark and spark is ok. Coils are fine as I switched them from the drivers side to the passenger side.
Also checked compression and compression is fine.
No codes are thrown
Any Ideas?
Old Apr 4, 2007 | 04:36 AM
GNs-r-slow's Avatar
Bondsman
try swapping in a known good computer, its free to check if someone has one for you to test GL
Old Apr 4, 2007 | 06:03 PM
Krautburner's Avatar
Scissor me timbers!
Do you have diod's for injector? If so see if the injectors are pulsating and not stuck open.
