Roller Rockers
Old Mar 10, 2007 | 04:19 AM
fordaorm's Avatar
Dirty ol Troll
Default Roller Rockers
I have basicly got a 99 explorer 5.0 engine with GT40P heads with a E303 cam in my Fox. Any of you think ill have clearance issues with the 1.6 rockers?
Old Mar 10, 2007 | 04:20 AM
Steve B's Avatar
brings his heater.
get 1.7's
Old Mar 10, 2007 | 04:23 AM
fordaorm's Avatar
Dirty ol Troll
ok with 1.7's you got any measurement on the push rods?? Or can you use stock length?
Old Mar 10, 2007 | 04:39 AM
Steve B's Avatar
brings his heater.
stock will probably work, but you should always measure, i've got some fms motorsport pushrods if you're interested stock length
Old Mar 10, 2007 | 10:54 AM
97305hpcobra's Avatar
you shouldnt have problems with the length of the push rods by changing the cam. only if u change the heads or have the block decked diffrent head gasket and so on. But is a good idea to up grade to harden pushrods is steve b has them . the extra rpms and spring rate can bend them.
Old Mar 10, 2007 | 11:00 AM
fordaorm's Avatar
Dirty ol Troll
Yea i did install a stiffer spring to help with the Valve float... How much for the set Steve
Old Mar 10, 2007 | 11:02 AM
fordaorm's Avatar
Dirty ol Troll
But do you think ill have Piston to Valve issues with the 1.7's? Pistons are fly cut from the factory...I know ill check when i install them but kinda like a heads up from peeps thats done it before..
Old Mar 10, 2007 | 11:04 AM
Steve B's Avatar
brings his heater.
$20 if you come get em.
as long as i don't need em, i have to measure them first to make sure i need longer, i'm having alot milled off my heads, so i may need shorter ones.
Old Mar 10, 2007 | 12:52 PM
i had gt-40's with a f cam and 1.72 rockers they cleared plus i had them milled. i doubt u should have a issuse with the e cam and 1.7 just do the valve drop check that way u dont have to take ur heads off.
