302 Timing Cover/Water Pump Bolts
Old Feb 8, 2007 | 02:33 PM
BAMF's Avatar
Thread TERRORIST
Default 302 Timing Cover/Water Pump Bolts
So, which bolts get what? Thread lock/moly lube/Teflon water sealent stuffs? Also, if you know it, what PSI do the stock bolts go to?
Links or advice works, just as long as you can be (resonably) clear with the instructions. Thanks in advance, guys!
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Feb 8, 2007 | 03:15 PM
shinysideup's Avatar
TR Balla Donor Supreme
chiltons is in english.
Old Feb 8, 2007 | 04:11 PM
BAMF's Avatar
Thread TERRORIST
Fucker.
So is Hayes, but someone omitted the section that says what gets what. Go figure...
Old Feb 8, 2007 | 05:00 PM
Sumthin Nuu's Avatar
Unsettling your debt
The 4 longest timing cover to block bolts (around water passages) should get anti-sieze on the entire bolt to keep them from corroding and lockin itself in the block many years down the road. Lots of people dont, but I've seen enough of them broken off flush in the block to know better. The shorter ones by the timing cover pointer, etc dont need anything other then bein cleaned with a wire brush. The gasket should get a thin coating of silicone (i use ultra blue) on both sides of the gasket around the 2 coolant passages. Its also a good idea to use to small globs of silicone on the 2 corners where the timing cover meets the oilpan in the front main seal area.
The waterpump to timing cover bolts dont need anything on them (except the ones mentioned above that go all the way thru the waterpump, timin cover and into the block) The waterpump to timing cover gasket should get the same light skin of silicone treatment all over the gasket, on both sides of course. Same thing for the thermostat gasket if you're replacin it.
Whenever you buy a new waterpump or if you're reusing a like-new one, take the metal backing plate off of it by removing the two 5/8" head bolts that attach it to the back of the pump. You'll want to again use the skin of blue silicone on all of this gasket front and back too. Inspect the casting for pitting damage where it meets the gasket, its rare but I've seen them leak b/c of it.
I usually just take a small amount of silicone on my finger (use gloves to keep it from dryin on your skin as its a little hard to scrub off unless u wash ur hands with comet or a SOS pad) and just rub the silcone on the gasket until the gasket gradually absorbs it and turns it darker, doesn't take much.
Sounds obvious I know, but not doin this shit usually ends up with you doin the job a 2nd time when u start pourin water back in the radiator and hear that lovely coolant start hittin the driveway from a leak at the waterpump/cover. Cant begine to tell you how many people used to call me because they did timing chain swaps or waterpumps and didnt know to use the silicone and had coolant all over their driveway.
Old Feb 8, 2007 | 07:43 PM
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
+1 on pulling the pumps rear cover , cleaning it up inside and putting a new gasket on! its a really stupid design that it held on by 2 bolts then uses the clamping force of your other bolts also. If it didnt leak from there before and u do everything right but that cover it will DEFINATLY leak on you lol
Ultra blue FTW
If your above stated 4 bolts look crappy in the least just replace them It will save u more then one head ache and swearing rant later.
Old Feb 8, 2007 | 07:44 PM
Mars_302's Avatar
Race Photographer
I use rtv all my bolts personally. ive only seen one rear gasket ever fail on a water pump and it was an old pump anyway.
Old Feb 8, 2007 | 07:58 PM
$hawn's Avatar
lives in a glass house
RVT on all.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Feb 8, 2007 | 09:07 PM
BAMF's Avatar
Thread TERRORIST
Well, I've got a brand new Edelbrock water pump I'm using. Thanks for the detailed info about the bolts and other advice, by the way. I really appriciate it!
