Need bare long block and trans
Old Feb 8, 2007 | 07:01 PM
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
Its got a 5 speed. Are yu sure you wan to go with a C4? how much power are you planning on putting down? Id think an AOD would make for a much nicer cruiser and still have the ability to have a lil kick to her but gain that high gear
Old Feb 9, 2007 | 03:19 AM
riverhead55's Avatar
Adam said that a aod is heavy and i would be better off with a c4.Im not going to build a lot of h.p. the car is very light,with a tall rear gear it should cruise good.I also like a carb.because its a open front end,and you can see the entire engine.Let me know what you think,and Pat when you have the old block out call me 352-585-0287.
Old Feb 9, 2007 | 03:48 AM
ODB's Avatar
ODB
S.Y.L.O.
will do.
Old Feb 9, 2007 | 05:53 AM
oohh I assumed it was going to be closed hood on a phaeton .... carbs work you gonna go with one 4 bbl? or somthing trick looking like two 4 bbls on a cross ram or tunnel ram? or a 6 pack set up?
