How much safe HP can a stock 302 make
all in the rpm too
^ Don't much matter, as long as its got the factory forged pistons. The block is the weak point - internals will take more abuse than that thin ass lifter valley on the block.
Someone on here made a lot more than 500 on a stock block and it didnt break. I wonder who.
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Does absolutely no good from what I've been told. Valley is still gonna split, and well...the bottom end girdle will offer a little help and keep everything from dumping into the pan when it does, at least.
Ive seen pictures of motors with girdles let go. You will are the rear three mains still attached to the block with the front two mains hanging down attached to the now crescent shaped girdle
pics or ban
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
Oh so u know u can push against the vally side and block side and flex the bored by hand right??? put a bore gauge in that bitch and try it. I didnt believe it till somone showed me and the gauge moved Ill be doing upper and lowers
yeah exceot there is a beam holding the lifter valley down and the top end squared up. Idk im sure they will help with my aluminum heads that are ported and polished out as far as they can go and going with a intake that must be portmatched and equally hogged out thats alot of structrual rigidity lost. where as with a cast intake thats not ported paper thin and cast iron heads im sure as u say it would be stronger. Then again our engine isnt going to be in a daily or even a car thats cruised . Its being built to run WOT for 9 seconds then idle back to the pits ect and just has such a massive amount of material removed from the heads and will also from the intake bolth being aluminum which is weaker then cast iron ect.
