nitrous questions
Old Jan 20, 2007 | 04:17 PM
VERTFIVEO's Avatar
HATES STUPID PEOPLE
Default nitrous questions
I have a wet kit I had used with a Y-nozzle on my LT1 after the mass air , can I use it on my Roller Motor the same? or is their a better way? I want to run a 125shot on it, if not, anyone have the parts I need to run it?can I run it as a dry shot before the Meter?..talk to me
Old Jan 20, 2007 | 04:20 PM
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
use a wet shot dude. Alot of people swear by dry shots but you must ask yourself WHY would u want a less sage and less tunable system? BTW they make the same single Y nozzel wet kit for mustangs
Old Jan 20, 2007 | 04:22 PM
VERTFIVEO's Avatar
HATES STUPID PEOPLE
ok, so what do I need to do? any special parts to tap into my fuel?....I have the BBK intake, with 24lb injectors, just get it up and running and have it tuned?
Old Jan 20, 2007 | 04:51 PM
ODB's Avatar
ODB
S.Y.L.O.
+1 for wet
Old Jan 20, 2007 | 05:00 PM
we ran a dedicated fuel pump and line when we sprayed my 68 camaro. U can probably just T into your line and run a 2nd preasure reg if u have a 255 intank pump and only 24lb injectors
Moroso Aluminum Y-Blocks - JEGS and run its own fuel preasure reg
Old Jan 20, 2007 | 05:04 PM
ODB's Avatar
ODB
S.Y.L.O.
T off your fuel rail
do u have a fuel presure safty switch? and a window switch if its a stick car?
Old Jan 21, 2007 | 04:36 AM
VERTFIVEO's Avatar
HATES STUPID PEOPLE
ive got a bigger fuel pump ready for it, is their and special deal to by to Y it off the fuel rail?
