What kind of compressor do I want?
Old Dec 21, 2006 | 07:11 AM
Stangonline's Avatar
Default What kind of compressor do I want?
I am looking for a good compressor for my home/shop. I would like to be able to use it for media blasting and also be able to paint with it. What kind of unit am I looking for? If you have a few different model suggestions, that would be great, as I am going to be looking for a used unit.
Thanks
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Dec 21, 2006 | 07:26 AM
Flastangs's Avatar
Usually bigger is better. I am gunna get the bigest tank I can afford on mine.
Old Dec 21, 2006 | 07:46 AM
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
+1 the ****** the better. the ones from like home depot that have horizontal tanks arent big enough for anything more then some quick short work.
Old Dec 21, 2006 | 09:31 AM
shinysideup's Avatar
TR Balla Donor Supreme
Two stage. 80 gallon. goes to 175 psi.
the single stage is more expensive to run and limited to 125-135 psi. an investmet you wont regret. I found a used cambell hausfeld and i love it. new from lowes the kobalt is 799.
Old Dec 21, 2006 | 09:38 AM
ODB's Avatar
ODB
S.Y.L.O.
Originally Posted by Mars_302
yes you can never have too big
Old Dec 21, 2006 | 10:45 AM
What about this? Pro Air Vertical 80 gallon Air Compressor
Old Dec 21, 2006 | 10:46 AM
or this Air Compressor
Old Dec 21, 2006 | 11:19 AM
Lumberjack's Avatar
is made outa laffy taffy
If you happen to find a used one that needs to be rebuilt i can help you out. i used to repair and rebuild compressor heads and run compression lines.
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Old Dec 21, 2006 | 11:29 AM
Duceanahalf's Avatar
is doing your girlfriend
Rotary screw compressor.
