Nitrous question...
I plan on spraying my car soon. I'm starting out with a 75 shot to see how it goes. Just wondering if theres anything I need to do before I spray.. Some say its fine on a completely stock motor, some say change plugs. Will the stock fuel pump be ok? Do I need to retard the timing any? Thanks.. Its a 99gt btw..
-Chad
-Chad
1999 Mustang GT 35th Aniversery
2007 Yamaha Raptor 700R
nah spray it, you'll be fine
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
once you get around 150 shot thats when plugs,pump and timing need thought about
Largo fl 33773
MV#72427
Largo fl 33773
MV#72427
Guest
Posts: n/a
The trick is to tell everyone you are spraying a 25 shot, then drop the dick in them quickly at the track.
Seriously, go a step pr two colder on the plugs and back the timing out 5-8 degrees. Then let er rip..
With that 25 shot that is.
Thanks guys. The majority of the kit is going on this weekend, just waiting for the arming switch deal that I ordered..
I would go 1 or 2 steps colder, close the gap on the plugs .035. Back some timing out, you can always put it back in slowly!!!!!! Better to be safe!!
Ic. Im gunna go a step colder on the plugs. Now for the timing will I have to buy a timing adjuster or is there a different way to do it? Once again thanks..
