Drag Race Alignments
Guest
Posts: n/a
Anyone else want to chime in on this ?
I have always read the following:
Camber should be set at zero, try to keep the front wheels straight up and down.
Toe-in should be zero, toe-in change should be kept to an absolute minimum.
Caster should be between three degrees and six degrees.
Sound about right ?
Sound about right ?
I had george's wholesale tire do mine
It is a street car you know,why worry about it
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Guest
Posts: n/a
So what you are saying is you got the non street car alignment ?
But seriously I want every possible thing to help the car track straight so any info in addition to this if this is not correct would be great.
zero camber, in my opinion, is not a good idea, i wouldn't want to go 200mph on the very outer edges of my volkswagon tires.
actually, i wouldn't want to go 200mph, like scott's race car, on the full surface of a volkswagon tire, go get some drag tires if you don't have them scott.
