Suggestions?
When I first get in my car and drive it for around the first 5-10 minutes it runs fine, but when it gets warm, the car will stutter/lose power when you try to get on it.
Things I have replaced/checked already:
Module on distributor
Cap/rotor/plugs/wires
mass air meter
What else could cause such a problem to where it runs fine for a couple minutes then the problem gets worse when you drive it longer.
I drove from brandon to plant city and by the time i got to plant city I could only use very very light pedal pressure to keep up to speed with everyone else. Then, when i drove back to brandon, everything was fine until the first couple minutes past by and by the time i got to brandon the same thing happened, only can put very light pedal pressure on it when accelerating, otherwise it will stutter, etc.
Any thoughts?
mass air meter
Any thoughts?
