Please Help Svo Conversion
Old Nov 13, 2006 | 03:02 AM
SPOOL U 1986's Avatar
Swamp Water.. Hot Dam....
Default Please Help Svo Conversion
Hello All,
I am purchasing a 88 coupe and want to do a svo conversion. I know a couple of folks on here have successfully done this, and was wondering if it would be worth it? I had a couple of questions - typically how much do the wiring harness cost?, where could I pick one up at?, would I need to change the dash out?, swap ecu ect... Does it matter if the ecu is for a auto or maunal?
Thanks for your help,
J-
"You dumb basterd that's not a schooner it's a sailboat."
2.3t-sold
95 GTS-New Toy
Old Nov 13, 2006 | 03:33 AM
power2weight's Avatar
-eats the last cookie.
First, you will probably want to start out with a hatch. Just my opinion though.
You can practically modify/repin any harness for the turbo cars sensors. Cophers won't even charge you anything for cutting pins out of harnesses.
Yes you'll want to run one of the turbo cars ECU's, along with the injectors.
"They must really feed each other to the lions down there........"
Old Nov 13, 2006 | 04:58 AM
Glassman's Avatar
Its just a four banger.
Here are a few links with info that might help.
http://http://www.turboford.net/faq/index.shtml
TurboInstall
Ford Ranger Turbos
Turbo Swap How To--Step by Step Instructions
Old Nov 13, 2006 | 07:14 AM
thank you for your help all
2.3t-sold
95 GTS-New Toy
Old Nov 13, 2006 | 04:49 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Your fucking gay!!!! So u bought a new car and never called on saturday. Thats it i'm cutting you off. Your no longer aloud to watch my stolen porn.....
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Nov 14, 2006 | 02:47 AM
NOOOOOOOOO!!!!!!!!!
I am picking up the car tonight... It is kinda close to Big Daves place so if you have time I could treat to a biggy diet coke to make up with some king size potato cakes..... yummy you know you want too..... all the cool people are doing it.......
2.3t-sold
95 GTS-New Toy
Old Nov 15, 2006 | 05:03 PM
plazma's Avatar
I think he is just doing a swap in a coupe. No real reason to try and make a clone when there are plenty of svo's to be found for reasonable money.
Good luck with the swap. Power2weight knows alot of the wiring so keep him in mind. Need help just post up.
https://www.tamparacing.com/forums/signaturepics/sigpic17840_1.gif
My Project
Old Nov 15, 2006 | 07:14 PM
As long as its not a turbo ranger swap the above is true
