Slave Cylinder Woes
Old Oct 25, 2006 | 04:36 PM
christo4_99's Avatar
Default Slave Cylinder Woes
I'm replacing the slave cylinder(inside the tranny) on a 95 Ford F150 with a 5 spd standard tranny and the line from the master won't lock into the receiver on the slave...anyone ever have this problem? lmk what i need to do...i don't wanna drop the tranny again if i don't have to.
Old Oct 26, 2006 | 03:29 PM
fyi all the replacement parts are compatible with each other...including the part you get from ford...none of which are compatible with the original parts...in other words you have to replace the slave master and line as a set to make it work...
