Underdrive Pulleys
Old Sep 13, 2006 | 05:31 AM
GT5.0HO_STANG's Avatar
Bred2Run
Default Underdrive Pulleys
Just wondering wat are the pros and cons with the underdrive plley kits
Old Sep 13, 2006 | 07:32 PM
LS1COUPE's Avatar
Destroyer of fords
ac not as effective at idle and if its a fox altenator it will be discharging at idle. i would keep the stockers and use a cobra wp pulley to speed it up.
if its a mod motor car i have never owned one.
Old Sep 14, 2006 | 04:18 PM
SVTd's Avatar
Also, depending on the size could spin the water pump too fast causing the car to over heat, to remedy you would also need to change out this pulley.
