EFI or Blow-Thru ?
I'm at the point where I don't know in what direction I want to go ..
I could do a MAF setup and a Tweecer or maybe Megasquirt ..
Alot of people have been having really good luck with the MS II and honestly i'm way more comfortable tuning a MAP based system thana load based MAF setup ..
I also see alot of people having pretty good sucess with Blow-Thru setups on TurboMustangs ..
So what do you guys think ?
Motor is a Stock Block (for now) 302 , E-Cam , GT40P's , GT40 Intake , 1.7 roller rockers ..
Eventually it's going to get an R-Block and forged internals , but I would like to see how far I can take the stock motor for now .
I'm pretty sure seeing 400-450ish WHP Should be enough to get this thing to Trap well into the 120 Range and into the 10's as well ...
Car will mostly only run Pump gas , Will see C16 at the track for a couple cracks to break teh block in half lol
Hondata saves lives
Hondata saves lives
Guest
Posts: n/a
I'm building an MS for an air-cooled VW application so I'm biased towards that. You can run an explorer front timing cover and run EDIS with the MS on your 302 so there won't be any distributor which could come in handy with turbo plumbing.
I'm running a 3½" Pro-M Univer blow thru with 50 lb injectors and using Tweecer. It works pretty good. There's a bit of a learning curve with the Tweecer if you don't know anything about ECU's like me but it falls into line pretty quickly. There are a couple of good support boards and a yahoo group for it. You can pick up a used R/T for about $450. Tuning WOT is really easy while the idle and drive around stuff is a little more involved but not much.
YO! Barry! You LOST!
caan I stop by and you help me with my 73 van?
Blowthrough,cause I got a whole 750hp carb fuel system for sale.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
This is what I was thinking as well .. I'm trying to find a bit more info on how well the EDIS is working on higher HP applications . I know when I ran MSnS on my MR2 I was having spark blowout issues above 18psi ..
I think for now I'm going to run a Pro-M with some 42's or 50lbers and a Tweecer for now . I'd like to get some tuning in with a MAP based on VE/Load tables just to expand my range a bit ..
Eventually i'll probally go with a Victor Manifold converted to EFI with an Elbow on it for the next motor ..
I wanna see a stock shortblock go 9's
Hondata saves lives
Hondata saves lives
The car is whatever I make it ..
I'm going to go ahead and do a MAF setup with a 77mm or 80mm Pro-M for now as thats what James recomended to me ..
Eventually i'll probally run a AEM or F.A.S.T. setup on the car
Hondata saves lives
Hondata saves lives
So helpful aren't we Scott lol
I've heard some horror stories about blowthru setups , and just as I said , I feel WAY more comfortable tuning on a laptop than I do with jets . I may still try it if I can get Mr.Bryan to sell me his blow-thru setup cheap
Hondata saves lives
Hondata saves lives
