Thermostat
Old Aug 24, 2006 | 07:41 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Originally Posted by maverick1090
Why even run a Thermo? I'd just go with out one. It's not like we need to heat cars up any faster in Florida?
HuH? do you even live here in Florida? I had a problem for a while with my car overheating cause I didn't have a thermostat. I'd go on a road trip on 275 and it would overheat found that out the hard way...
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Aug 24, 2006 | 08:18 PM
maverick1090's Avatar
Redneck Racer
I guess I'm having trouble seeing how not having a thermo would overheat your car? Having one would bring the engine up to operating temp faster, but after 180 would remain open the entire time? That was always my impression?
Old Aug 25, 2006 | 06:14 AM
Na306StAnG's Avatar
The point of a good cooling system is for the thermostat to stop/slow the circulation of water through the motor to bring the motor up to operating temp sooner. But once the motor is at the thermostats temp it will open and allow circulation of the water that was in the radiator allowing it to cool the motor. At 80 MPH on 275 my car sits at about 2,500 rpms. If I drive from Clearwater to Lakeland as I did that day with no thermostat. There is no way for the circulation of water to slow/stop circulating hence your water temp will just keep getting hotter and hotter. If you drive your car around town and never hit open road for longer then say 30 mins you'll be fine with no thermostat.
Largo fl 33773
MV#72427
Old Aug 25, 2006 | 07:52 AM
fordaorm's Avatar
Dirty ol Troll
I run a 180 in my 93 GT dont have any probs i do have a 4 core rad and that makes a big diff..
Old Aug 25, 2006 | 01:50 PM
Redneck Racer
See.. you learn something new every day!
Old Aug 26, 2006 | 02:19 PM
Whaazup17's Avatar
huh... well I got a thermostat it was like 5 dollars going to replace it and the gasket with the coolant
