Overheating 5.0
Old Aug 14, 2006 | 06:09 PM
DetroitMuscle's Avatar
Default Overheating 5.0
I have just purchased a 1987 Mustang GT (original - no mods). I changed the water pump, upper and lower radiator hoses, the bypass hoses, Thermostat and housing, timing cover gasket. Still Overheating.....
I removed the thermostat to see if the radiator had flow and yes it did. I'm starting to think it’s the head gasket.
Any input on a solution welcomed
-Thanks
Destination Unknown
METHOD TO MY MADNESS
Old Aug 14, 2006 | 06:10 PM
Duceanahalf's Avatar
is doing your girlfriend
a bad head gasket will most likely put oil in the water or water in the oil.
Old Aug 14, 2006 | 06:11 PM
fordaorm's Avatar
Dirty ol Troll
Does it run hot drivin down the road or just sittin still or movin slowly??
Old Aug 14, 2006 | 06:21 PM
Road Rage's Avatar
Shake n' Bake
fan clutch?
Old Aug 14, 2006 | 06:28 PM
shinysideup's Avatar
TR Balla Donor Supreme
Originally Posted by Road Rage
fan clutch?
werd
Old Aug 14, 2006 | 06:37 PM
Could the head gasket leak out the exhaust?
It runs hot sitting still, driving down the road, and even watering the radiator down.
fan clutch?
Sorry..... I forgot to put down the fan clutch, used off of my part pile from '93. ( Heavy Duty Fan Clutch)
Destination Unknown
Old Aug 14, 2006 | 08:02 PM
Road Rage's Avatar
Shake n' Bake
are you sure its overheating and not just the gauge, is it like boiling out?
Old Aug 14, 2006 | 08:17 PM
After the factory gauge reaches 270 + the car starts smoking out of everywhere under the hood.
Destination Unknown
Old Aug 14, 2006 | 09:06 PM
Pshull727's Avatar
dose the rad bubble when the car is runing or does the oil look like a milkshake.
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old Aug 14, 2006 | 09:24 PM
The oil is in perfect condition.....
All you see in the Radiator is the water flowing.....
Destination Unknown
