Need some help again.
Old Aug 11, 2006 | 04:20 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Default Need some help again.
OK got a new ? I have an AOD with the O/D electrically activated. I'm trying to figure out if there is a way to turn it on and off via the on/off switch on my streering wheel that was used for the cruise control. the cruise control is long gone.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Aug 11, 2006 | 08:14 AM
Na306StAnG's Avatar
Originally Posted by Just Dave
I believe the Len Tech's use a switch to engage OD. If that's the case, then you could use the cruise switch. I'm not sure how it needs to be wired so I can't give specifics though. Maybe search Corral?
The tranny in my car now uses a switch its a P.A./CRT. thanks for the heads up.
Largo fl 33773
MV#72427
Old Aug 11, 2006 | 03:13 PM
Steve B's Avatar
brings his heater.
Well if you know that a switch can work, then you should be good. I think the easiest way would be to use the cruise on/off switch since I think all of the others are momentary. What year is your car? I may be able to get you the wiring colors from my Chilton manual.
doesnt that switch also turn off below 30 mph.... neat.
Old Aug 11, 2006 | 03:21 PM
Zman's Avatar
I gota Cheby
On my coupe I used the headlight switch assembly. used the fog light portion out of a GT and the harness is there surprisingly when you swap plugs. Even the wires are there sitting where the Fog light are. I have a coupe. I even swaped the face of the GT fog light sticker and used my blank face from the lx for a stealth look. (armed my nitrous with it)
Only 1/4 mile track I know is Gandy Bridge
Old Aug 11, 2006 | 08:11 PM
Na306StAnG's Avatar
WoW thats sweet i'll have to steal that later
Largo fl 33773
MV#72427
Old Aug 11, 2006 | 08:12 PM
Na306StAnG's Avatar
its an 88 coupe 4cyl auto
Largo fl 33773
MV#72427
Old Aug 13, 2006 | 08:50 AM
Na306StAnG's Avatar
trying to get this done today. any other ideas on how to do this!!!!!!
Largo fl 33773
MV#72427
Old Aug 13, 2006 | 09:21 AM
the anti-rice's Avatar
finally painted the car!
if you could findout what wires are coming off the c/c switch you could take then to the o/d wires. you need to findout what wire is the signal, power and ground (if there is one). OR just put a regular switch somewhere in the car that would turn o/d on/off.
I used a fog light switch in my 94 to power my fan. but the c/c button sounds like a good idea aswell. good luck. let us know how it turns out.
-Ryan-
