Oil pressure light <updated turbo install pics>
Escort Connoisseur
on
Hey all,
Well I've got the turbo install almost done. One problem though. The oil pressure light keeps coming on as soon as the turbo spools, I checked the oil and it's at the level, unless maybe I need to overfill it to compensate? Any ideas from all you turbo gurus out there? I had to tee off the oil pressure switch to run the oil line to the turbo by the way.
Here are some pics anyhow...
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
Escort Connoisseur
on
I tapped the oil pan for the retun line and used a tee for the in line..
Escort Connoisseur
on
I'll try that on Monday, I left it at the shop over the weekend. I replaced the switch when i put the turbo on with a discount auto parts one, I'm wondering if maybe they gave me a bad one or something. The old one worked fine.
Escort Connoisseur
on
If I was done, and dyno'd I might tell you. But I just finished and haven't worked the bugs out, so no idea. It's a motor, it can be turbo'd, that's the point. Doesn't really matter what kind of car it is.
All said and done I'd like to make about 200hp, in a 2300lb car. You do the math
make sure your oil pump is not going bad... this happened to my car when i turboed it and the oil pump got mess up, my oil light will come on too...
nice sleeper you got there btw...
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
I'm looking at dyno'ing 240-250 with a good tune on mine once the kit is on it. A built bottom end D20 is making 350 to the wheels. But before I get into all that I must add the LSD and finish my suspension.
