Is there a site to check for recall's?
Chucking up the Dueces
on
My friend has a 2002 mercury mountaineer and both front wheel bearings took a shit,I know because I just changed them Car has allways had factory wheels on it,and has 44,000 miles on it.I just thought it was weird that both sides went at once,so I figured I would post it here.
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
http://www-odi.nhtsa.dot.gov
Search Results
Report Date : August 3, 2006 at 10:58 PM
SEARCH TYPE : VEHICLE
YEAR : 2002
Make : MERCURY
Model : MOUNTAINEER
Type : ANY
Results : 2 | All records displayed
Make : MERCURY Model : MOUNTAINEER Year : 2002
Manufacturer : FORD MOTOR COMPANY
NHTSA CAMPAIGN ID Number : 01I010000 Recall Date : APR 10, 2001
Component: VISIBILITY:GLASS, SIDE/REAR
Potential Number Of Units Affected : 50224
Summary:
THIS IS NOT A SAFETY RECALL IN ACCORDANCE WITH THE SAFETY ACT. HOWEVER, IT IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN BY THE AGENCY. VEHICLE DESCRIPTION: 2002 FORD EXPLORER AND MERCURY MONTAINEER SPORT UTILITY VEHICLES. THE BRACKETS CONNECTING THE LEFT CYLINDERS TO EACH SIDE OF THE LIFTGATE GLASS COULD ROTATE OUT OF POSITION IF EITHER THE URETHANE BOND OR TORQUE ARE NOT SUFFICIENT.
Consequence:
ROTATION OF THE BRACKETS COULD POTENTIALLY CAUSE THE LIFT CYLINDERS TO DETACH FROM THE GLASS OR, IN SOME CASES, COULD POTENTIALLY CAUSE THE LIFTGATE GLASS TO BREAK. EITHER CONDITION IS MOST LIKELY TO OCCUR WHEN THE GLASS IS BEING CLOSED.
Remedy:
FORD DEALERS WILL INSPECT THE VEHICLES FOR THE POSITION OF BOTH THE LEFT AND RIGHT LIFTGATGE GLASS LIFT CYLINDER BRACKETS. IF THE BRACKETS ARE IN THE PROPER POSITION, THE BRACKET RETAINERS WILL BE TIGHTENED TO A HIGHER TORQUE. IN CASES WHERE THE BRACKET IS NOT PROPERLY POSITION, THE BRACKET MUST BE RE-ALIGNED.
Notes:
FORD HAS DECIDED TO CONDUCT A SPECIAL SERVICE CAMPAIGN TO INSPECT AND TORQUE THE LIFTGATE GLASS BRACKET ON AFFECTED VEHICLES. OWNERS CAN CONTACT FORD AT 1-800-392-3673, CONCERNING THIS PROGRAM.
Check to Request Research. Submit below.
NHTSA CAMPAIGN ID Number : 01V171000 Recall Date : MAY 21, 2001
Component: TIRES:SIDEWALL
Potential Number Of Units Affected : 52000
Summary:
VEHICLE DESCRIPTION: SPORT UTILITY VEHICLES. THE RIGHT SIDE TIRES MAY HAVE HORIZONTAL CUTS ON THE EDGE OF THE TREAD THAT COULD HAVE OCCURRED DURING VEHICLE ASSEMBLY.
Consequence:
OVER TIME, THE TIRE COULD FAIL, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT THE TIRES AND, IF ANY SLICES ARE FOUND, THE CUT TIRES WILL BE REPLACED. OWNER NOTIFICATION BEGAN JUNE 7, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-800-392-3673.
Notes:
ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
YEAR : 2002
Make : MERCURY
Model : MOUNTAINEER
Type : ANY
Summary:
Consequence:
Remedy:
Notes:
Summary:
Consequence:
Remedy:
Notes:
Helmut
Helmut
Guest
Posts: n/a
