need a bearing pressed
Old Jul 26, 2006 | 05:48 AM
MISSINGSTANG's Avatar
NEEDS A COUPE
Default need a bearing pressed
Ok got mosier axles with the c clip eliminator, the bearing went bad after about 1000 miles. Called mosier and they sent a new one out to me. I need someone with a press and knowledge to pull the old c clip eliminator off the axle and pull the old bearing. Press the new bearing on and then put the whole thing back on the axle. Anyone know someone/somewhere?????
YOU CANNOT KILL WHAT YOU DID NOT CREATE
http//www.myspace.com/truebluerangers
Old Jul 26, 2006 | 06:02 AM
BigBird's Avatar
Any machine shop should be able to take care of that for you. I use the NAPA Machine Shop located on Florida Ave just north of Fowler in Tampa.
10 SS/RS
06 Busa
Old Jul 26, 2006 | 06:10 AM
Pimpin92camaro's Avatar
ive never used em but friends of mine have and carquest seems to do a decent job from what i hear....
Old Jul 26, 2006 | 06:30 AM
NEEDS A COUPE
Yeah but you have to press the c clip eliminator off the axle then repress it back on.
I have a press to do bearings, thats not the problem.
