help
Old Jun 25, 2006 | 08:17 PM
Slow5ho's Avatar
Default Need Tweecer Help Please
looking for someone to help me with me tweecer r/t. wanting to set up the car for a motor tune need to lean it out have an a/f of about 9.9 to 10.5:1 when in high rpm. car wont turn up past 5800 i think it is due to the extra fuel
255LPH PUMP
42LBS INJECTORS
76C&L MASS AIR METER GREEN TUBE
75MM THROTTLE BODY
MALLORY RAILS AND REGULATOR
HAVE FUEL PRESSURE AT 25LBS TO TRY AND LEAN IT OUT A LITTTLE
10.5:1 COMPRESSION
MIGHT HELP WITH SOME TUNING HELP
PLEASE HELP
feel free to call
813-917-6686
Old Jun 26, 2006 | 02:34 AM
DrDirt's Avatar
Team Geritol Racing
I'm assuming you are running an A9P or A9L. If all else is good and your MAF curve is dialed in, all you need to do is lean out the WOT, you do that in the Base Open Loop Fuel Table. Set the top row to what you want your AFR to be. (If you're running that rich though, it sounds like your MAF Transfer function is not right)
If you don't have one yet, I'd suggest getting a wideband to monitor your AFR. I have the PLX M300 and it works like a charm. Also, EEC Analyzer by Clint Garrity is the greatest thing since sex and whipped cream for analyzing your datalogs.
YO! Barry! You LOST!
Old Jun 26, 2006 | 07:50 AM
Slow5ho's Avatar
i have an innovate lc1 wide band. i will try that thanks for the help do you go out on the weekend i would like to get together with you if you wouldnt mind to show me the ropes of the thing. i would greatly appreciate it
Old Jun 27, 2006 | 09:21 AM
Slow5ho's Avatar
anyone else have tweecer please help
Old Jun 27, 2006 | 10:17 AM
DrDirt's Avatar
Team Geritol Racing
I go out from time to time but my car is down right now redoing the turbo and intake. That probably means my old tune won't be worth beans now. Would be glad to talk it ver with you. I'm in largo, I see you're in PC...which one, Port Charlotte, Pasco County, Ponca City, Oklahoma?
Oh, btw, set your fuel pressure back to 39 with the vaccum off.
Lots of good online reading and help at http://eectuning.org/forums
Old Jun 27, 2006 | 11:34 AM
Slow5ho's Avatar
ok will do and it is plant city: motor is a nitrous motor but tring to get it to run good on the motor before i can run the bottle. i tend not to run my vaccum on my reg.
