Ford Experts Help Needed
Old Jun 19, 2006 | 11:10 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
I hope I helped...
Old Jun 19, 2006 | 11:12 AM
TampaMille's Avatar
Resident Ham-N-Egger
Yeah, you definitely helped. You confirmed what I thought wasnt even an option. Just couldnt believe a battery would keep it from starting, but youre right. Its the only thing left.
Old Jun 19, 2006 | 11:27 AM
9050LX's Avatar
Dead battery could make your alternator overheat also, not good for most run of the mill alternators.
Old Jun 19, 2006 | 04:25 PM
fastpony89's Avatar
I also own a 1990 bronco II and had the same problem....what I did was replace the positive/negative cables because they were corroded along with replacing the starter solenoid...nothing was wrong with the battery at all and fired up again...you can pick them up at autozone and spend about $20...it is not a bad job to do by yourself just need some patience....good luck man
Old Jun 21, 2006 | 12:32 PM
jmdoc66's Avatar
I'd check the battery cables. Could be corroded inside.
