To what extent can you....
on
To what extent can you modify a speed density car before it starts to give you problems?
I know that Cams are almost out of the question (unless you guys know differently)
But what about modifications to the heads like rockers or springs, intakes and stuff like that?
Ain't it only like $350 or so to go over to mass air?That would be my first mod.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
speed density is actually better for performance than mass air. I oul do heads, e cam, itake, 24 lb inj, fuel pump, exhuast and get a tune
ASKED TO BE BANNED
ASKED TO BE BANNED
on
I don't know what it is man but piercy has the car right now and im telling you its the best thing we've done for it in a long time. He has fixed all of the stuff that every other shop cut corners on and I only owe him 50 bucks up to this point. major props to him for helpin me out
He wants to take it back to speed density because no one can figure this issue out which is why I asked the question.
The guy who assembled my engine - did not shim the rockers and it is probably causing the valves to hang open because they are tightened so tight. Piercy has already informed me hes gonna go back through everything almost to look for problems. If anyone can fix it, its him
on
Will a speed density car run with an e cam? because if thats the case ill have my car back tomorrow ill just tell him to take the mass air conversion out
I know someone running an F cam, GT40p heads (w/ crane RR's, etc), 24lbs injectors, exhaust, fenderwell intake, HV oil pump- all on a speed density system. All that was done was some fuel pressure adjustments, and hooking up a timing light to make sure everything was right, and it doesn't run overly rich or anything. Daily driven too.
fear is your only god
it will idle like shit until you get a tune, and it will run a lil on the rich side, a e cam has more lsa than a f thats y a e sounds bigger. you should be fine with a good tune
ASKED TO BE BANNED
ASKED TO BE BANNED
on
I need specs because just saying adjusting the fuel pressure and timing does nothing for me get ahold of your friends and find out what they've done. Please.
