got some problems at the drag strip
Old May 31, 2006 | 04:25 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Originally Posted by Duceanahalf
You said it launches, but falls, then picks back up. Do you have jet extensions in the rear of the carb?
Yea its an HP Holley its got jet extensions
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old May 31, 2006 | 04:55 AM
evocrazy1's Avatar
i had the same issue with my EFI car running NGK's in aftermarket heads
ASKED TO BE BANNED
Old May 31, 2006 | 05:02 AM
Zman's Avatar
I gota Cheby
Sounds like somewhere in the carb, I had the same kind of problem on my Holley a while ago. What size carb do you have? Have you played around with the squirters and the pump shots. Sometimes when you leave its on the primary circuit and then when you transition to the secondary circuit takes over there can be a bog from a weak vac signal. Thats what happened to mine and had Barry Grant advise me on it. He did live in St pete at one time.
Only 1/4 mile track I know is Gandy Bridge
Old May 31, 2006 | 11:38 AM
Na306StAnG's Avatar
I have a tranny brake in my car. So i stage my car and hold the tranny brake and push the pedal to the floor and the 2 step kicks in at 3300 i let go of the tranny brake and the 2 step shuts off. the car launchs but goes no where till about 100 feet out then takes off. I think there is something wrong with this bull shit tranny again worst fucking money ever spent.
Largo fl 33773
MV#72427
Old May 31, 2006 | 12:52 PM
Na306StAnG's Avatar
well the new rear is in off to grab some food ,fuel and off to the track.
Largo fl 33773
MV#72427
