twin 255 intank question
Guest
Posts: n/a
I'm guessing this is a car that didn't come with them from the factory? If so, I would use the stock fuel pump relay and circuit since its controlled by the computer and already there. However, I would use that factory wire as a turn on for 2 standard Bosch relays (from any auto parts store). Run a nice thick wire directly from the battery (fused of course) back to the relay's (you can run one wire and split it at the relays). Basically since the stock circuit won't power 2 pumps, you're using it to turn on 2 relays which will each power a pump.
so your saying with the 2 relays i use the power from the stock pump wire to ture on /off , and run my own power , do you or any one have pics of how they wired the relay? thanks
