What Plugs To Use With Nitrous??
well i took my car to the track thursday and i had the bottle full first time on the nitrous at the track .....i have autolite 25 plugs on there the stock ones and the car destroid the plugs only 2 survibe after a really bad nitrous explosion out of the carburator.....what plugs do u recomend to use with nitrous its a carburated 306 with a wet 200 shot of nitrous i also run race fuel too...what plugs are for nitrous and what should i set my timing at ???? help a young brother out
i run 3923
-Ronald Reagan
-Ronald Reagan
you definately need atleast one step colder...but torching the plugs like that...especially with race fuel (100 octane?) means your tune is off quite a bit. You need to see how lean or rich you are and you should also probably pull about 5-7 degrees from where you run NA. Id shoot for 11.5 to 1 for the air fuel.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
you cant run an autolite 3923 in a stock head...what heads are on the motor eddie?
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
