4 cyl. tranny swap
Old Apr 4, 2006 | 04:46 PM
gtmike's Avatar
Default 4 cyl. tranny swap
im puttin a 4 cyl. T-5 in my 90' GT and wondering if i can use a 4 cyl. tranny mount,the neatral safty switch connections are different on the tranny than on the harness,and tranny crossmember does'nt line up with the mount.thanks in advance.
Old Apr 4, 2006 | 05:21 PM
blown1989stang's Avatar
the crossmember is different double hump to single hump for exhaust
Old Apr 4, 2006 | 05:42 PM
gtmike's Avatar
it's a 90 gt manual car with a double hump cross member,i bought a 4-cyl. tranny with the mount assuming it would line up with the cross member,i put it in today but the cross member holes do not line up with the mount,the holes sit to far back from the mount.
Old Apr 4, 2006 | 06:34 PM
$hawn's Avatar
lives in a glass house
the tranny case is the exact same. it has to fit.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Apr 4, 2006 | 06:42 PM
gtmike's Avatar
it's the T-5 tranny that JDL1000 sold,the bellhousing is off a 91'gt.
Old Apr 5, 2006 | 12:07 AM
JDL1000's Avatar
Mike the 4cyl 93 LX the T5 came out of had a double hump crossmember just like your GT. Everything should line up. The cross member only goes in oneway for the trans mount to line up. Make sure you don't have the crossmember reversed. If you need help give me a call..
(Jason)
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Old Apr 5, 2006 | 03:12 PM
topher469's Avatar
BillionClub Member BISHES
make sure you changed you pilot barring too. It wont last long if you don't.
